Are there any program that you guys know of that are free and easy to use that can transfer VOB files to MPEG?
Thanks.!
Results 1 to 13 of 13
In reality VOB files are MPEG2 ones with subpicture and navigation private streams. Size of both of them is too small.Originally Posted by hellfire45
What do you need afor?transferingmy AVI Trimming guide
https://www.videohelp.com/forum/viewtopic.php?t=283241 -
They are DVD's that i bought. However, the subtitles do not fit on my TV, they get cut off..I wanted to see if reburning them as mpeg's would fix the size problem.
Are the subtitles burned into the image, or propper DVD subtitles ?
If they are burned into the image then you will have to resize then reencode to correct the poor placement.
If they are DVD subtitles then you may be able to change the position of the subs using IFOEdit. You would have to rip the disks to your HDD, then alter the IFO files, then write it back to disk.Read my blog here.
I suspect that they are burned onto the image. When I play them on my computer in windows media player or whatever, I can read them just fine. Its only when I put them up on a Tv.
Read my blog here.
If you can see it then your playback device is converting it OK. Perhaps the distortion is from the conversion, but it won't help the text being cut off as both have a width of 720 pixels. Converting PAL to NTSC seems to be more trouble than it's worth, but there are plenty of guides here to show you different options. The favourite seems to be the method based on DGPulldown, so that is probably a good place to start.
Read my blog here.
SubEdit may help you out:Originally Posted by hellfire45
-drjSubEdit allows you to visualize and modify some aspects of the subtitles in an already authored DVD. Subtitles can be moved up and down directly inside the VOB, without the need to demux/remux the subpic streams. Simply drag/drop one or several VOB files onto the main window.They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
At least it may help confirm/deny his suspicion that they are burned in.Originally Posted by guns1inger
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 13:24 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 09:00 -
vob and mpeg to dvd
By Dekaspace in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2008, 19:36 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 20:08
