Hey guys I'm in the market for a set of 2 or 2.1 computer speakers. I really don't care about sound that much because most of the time I will be using my 5.1 system. The three things I would like to have are:
1. The power button, volume knob, and headphone jack on one of the
satellites and easily accessible.
2. The cables to be nice and long so that the speakers don't have to be
super close together.
3. Black in color
If anyone can recommend a pair of computer speakers that fits these requirements I would very much appreciate it.
Thanks a ton
Tim
I don't know where you live at, but these are some Altec Lansing speakers from a California mail order company. They have other brands also.
http://www.computergate.com/products/prodlist.cfm?prodseq=J6M201
If that link isn't up, the company is http://www.computergate.com -
these are convenient..
http://www.walmart.com/catalog/product.do?product_id=4064462 -
If on a budget, the 40 watt Cyber Acoustics CA-3550 are a great value.
These speakers sound fantastic playing games or music. The Volume, Bass, Power, and Headphone jack is located on one of the satelites. Having a separate power button allows you to maintain a steady volume instead of having volume and power in the same control. The headphone jack is concealed on the side of the speaker. They look great and include 7 foot speaker cabling. -
Take your pick... http://www.directron.com/2pcswsub.html
I have and really like: http://www.directron.com/hk595.html , but it's not black.
JSB -
I like logitech x230 for budget 2.1.
http://www.newegg.com/Product/Product.asp?Item=N82E16836121119
fixing shorted computer speakers
By gooberguy in forum ComputerReplies: 15Last Post: 18th Jul 2010, 21:22 -
Using PC Speakers on Computer and TV
By imdaman in forum AudioReplies: 3Last Post: 26th Jun 2010, 23:41 -
Using computer speakers for my tv.
By imdaman in forum AudioReplies: 12Last Post: 28th Nov 2009, 10:47 -
How do you play music on the computer using all 6 speakers?
By Obamargarine in forum ComputerReplies: 5Last Post: 10th Mar 2009, 16:40 -
Best computer speakers
By justalice in forum ComputerReplies: 13Last Post: 11th Apr 2008, 13:34
