I have recorded a digital program from my SD set top box. Although the broadcast is 16:9, the actual program is from 1984 and hence is 4:3. So it has the vertical bars down the sides. My problem is, when capturing (Winfast TV2000 deluxe card) using Winfast PVR, it is always stretching vertically. This is happening no matter what capture reswolution I choose. I started wih 720X576. I thought this would record exactly as per the VHS source. Not so. Winfast PVR playback of the file looks fine, but if I playback using anything else, it shows that it is vertically stretched. If I try to capture using Windows Movie Maker, it says that my device is in use (even when I have shut down Winfast). When I try and capture using Cyberlink Power Producer, it immediately shows the source as being 'verticall stretched' before I even record it. Can somebody please help. This is the first time I've taped to VCR from the dig STB and tried to capture to PC for DVD burning.
Jon.
Try patching your original mpeg 2 file with DVD Patcher and play with the aspects
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Panasonic AG-1980 VCR and PAL vhs
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2009, 14:50 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 09:21 -
Help - Non-VHS format VCR choices & PAL-compatible hardware
By PLC401 in forum RestorationReplies: 28Last Post: 7th Mar 2009, 19:26 -
Where to get a PAL VCR to play Eutopean VHS Tapes?
By tezarin in forum Newbie / General discussionsReplies: 8Last Post: 11th Jul 2008, 16:48
