Im am trying to print some dvd covers off in nero cover design v6. The trouble is it makes the printed image too big by about 8-10mm each way (roughly), even when i specify the size as 274mm x 183mm any ideas anyone ?
Cheers Jim
I've never used the Nero software, but the software that I use has a menu option to "over print" the cover beyond the set boundaries. Bascially it allows you to print outside the set cover boundaries, which is nice because you don't end up with white borders around your cover if it isn't aligned properly. Maybe Nero has something similar.
Google is your Friend -
No problems with it here. Don't you have the light black lines to adjust the size to?
Try this one : Intercover
http://home.swipnet.se/intertax
A free one for all .
Works well for most needs .
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 04:28 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 20:21
