Hi, i have a few RMVB files which i converted to DVD files. How can i burn afew espisode into 1 DVD? thanks.
thanks for the link Baldrick. But how can i burn them into dvd? With 2 espisode into 1 dvd? thanks again.
This thread discusses using AVISynth to read RMVB files:
https://www.videohelp.com/forum/viewtopic.php?p=987885#987885
You can open the AVS script in TMPGEnc and encode as MPEG for DVD. -
If your videos are DVD compliant, (See 'What is' DVD) to the upper left) you just need to author them and then burn to DVD. If they both are small enough to fit on one DVD, you put both into the authoring program and it generates the needed file structure for a DVD. It can also create a menu to select which video you want. I use TMPGEnc DVD Author, but there are others here in 'Tools'. You can also find guides for Authoring to the left.
stand-alone DVD player that plays both rmvb and flv files?
By spiffy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Dec 2009, 01:46 -
burn RMVB file to DVD to play on standard DVD player
By samoyed in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2009, 21:29 -
I've got a problem with some .RMVB files
By architectofpain in forum Video ConversionReplies: 6Last Post: 18th Dec 2007, 22:47 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 05:53 -
HK serial rmvb files cant be converted!!!!!
By queenkong in forum Video ConversionReplies: 3Last Post: 14th May 2007, 12:23
