Sorry... I didn't know where to ask...
I've lost the DC power lead for my camcorder.
It's the lead that allows to connect from the camcorder to the power adapter for the battery and use with direct power.
I've done a few searches on ebay... but have had no luck.
What is the correct name for the wire?
It should only cost a very small amount.
If I can't get from ebay... can someone recommend somewhere in the UK?
Thanks.
OM
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
IMGBurn no lead-in with +R discs
By samijubal in forum DVD & Blu-ray WritersReplies: 21Last Post: 17th Sep 2010, 15:50 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
jvc gz mg505 av lead
By merray in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2008, 05:08 -
Lead contamination warning found on new laptop PS
By ahhaa in forum ComputerReplies: 10Last Post: 15th Dec 2007, 13:41
