Does anyone know of an authoring program (professional or consumer) that allows the user to author compliant mpeg-2 files simply by dropping into a predefined folder? For example, Canopus Procoder 2.0 allows the user to set up a "watch folder" that is constanly monitored for new files. When a file is pasted to the watch folder Procoder begins to convert it based on a user defined template. So, dropping a file into folder "x" would convert, say, an avi to mpeg-2 with 2 pass vbr encoding and noise removal. Or, dropping a file into folder "y" would convert an avi into wmv, etc...
Is there an authoring tool that has a similar setup? For example, dropping a compliant file into folder "x" would author an image with 5 minute chapter previews and a specific menu design. Or dropping a file into folder "y" would author an image with no chapters and no menu, etc...
Thanks.
Its been 1 1/2 years since I first asked (see original posting date)....Any newer apps or versions that can do this or something similar?
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 06:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 05:37 -
AVC H.264 MP4s displayed black by VirtualDub upon drag'n'drop
By bulgom in forum EditingReplies: 22Last Post: 6th Apr 2011, 21:18 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 04:26 -
HDTV2DVD will not let me drag and drop .ts file into "assests"
By Dollybono in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Mar 2009, 06:38
