    Nov 2005
    I have a problem with burning my dvds, the picture makes me dizzy when I watch it.
    I use the Dazzle digital video creator 150 Hi-Speed capture card (which saves as mpeg). I use TMPGEnc 3.0 XPress to edit the mpeg and TMPG DVD Author to create the DVD file, and Sonic Recordnow DX to burn the disc. The video I'm attempting to convert is a videotape recorded in SLP mode.
    WHen I watch it on the DVD player, the picture appears to be "shiny" and makes me dizzy to watch it.
    Can anyone help?
    USA
    Can you post a screen shot? Look here for instructions: https://www.videohelp.com/forum/viewtopic.php?t=271697
    And is it only like that when you view it from the DVD or before in the DVD creation process?
    Nov 2005
    Something i forgot to mention - the files captured are mpeg interlaced, and are changed to progressive when run through TMPGEnc.
    Also, It seems like it might be that the picture on the captured video is lighter then the original video. Anyone know how i could fix this? Contrast, i think might be the problem, but i'm not sure.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Why are you deinterlacing in TMPGEnc ? If the source is interlaced, it's best IMHO to keep it interlaced
    If in doubt, Google it.
