In reading manuals for Panny DMREH50 & JVC DRMX1S I found out that both only record LPCM digital audio in XP Mode. this seems backwards to me. If XP is a higher bitrate record than SP it would stand to reason that there would be less bandwidth available for audio and unless I'm mistaken LPCM carries more information than Dolby digital 2.0 which is the audio mode in all other speeds.
I'm #3 and I don't even try!
I think their feeling may be that if you give a crap about quality in the first place, i.e. xp mode, you would WANT lpcm rather than adc-3. Right?
I think DVD HQ (1 hour) and LPCM audio are targeted to MiniDV camcorder sources. Only camcorders offer highest quality SD video playback and the native DV audio format is PCM.
The only other high quality video source found in the home is the S-Video output of the cable/dbs/OTA tuner box. They prefer that you don't capture AC-3 from these sources.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 15:38 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 22:06 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
