    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    No matter what I do I can't backup my Titan AE DVD. I can't even make my DVD-RW drive reads it.
    The disc is playable on any standalone player on the house and my DVD-RW drive reads anything without a problem.
    But seems like they do not "match". My drive keeps trying and trying and trying to read the DVD and no success.
    I tried using AnyDVD and no success also. The drive just reads like mad and doesn't find anything. DVDFab (and Windows Explorer) says there is no disc on the drive.
    Any clue?
    Bruno
    USA
    I backed mine up with no problems, just using Shrink. You might want to check the disc for surface damage. A settop player can ignore a lot of damage that a disc copying program won't.
    Or if you have one available, try another drive for reading. That DVD has been around awhile, it should be easy to backup.
    Apr 2005
    The surface seems ok, no scratches or something like this. I'll try on another drive. But it's strange, my drive reads everything else with no problems at all.
    Anyway, thanx for replying.
