I use TMPGEnc DVD Author for producing my own DVD disc but I have problem to play discs in some DVD players. For example they are played well on my QUADRO DVD but on some DVD players which has not "SELECT" button on their remote control (only PLAY) button, disc can't be played.
I have one DVD disc (wedding party), with main many and chapter many and it can be played by pressing "Select" buton on selected field, then can be played by double pressing "Play" button on remote or by pressing 1,2,3 or 4 number button on remote (there are four scenes). I don't know which programm is used when this DVD disc is create, but I know that when I create DVD disc with TMPGEnc DVD Author only working button for playng the disc is "Select" or "Enter" buton. So the main question is how to create DVD disc for playng on almost all players (some players has not Select button, only the Play button).
Best Regards.
QUALITY HAS A NAME
https://www.videohelp.com/forum/viewtopic.php?t=270121
Might be something that'll help you out .
Dosent use "select" , this is the reason I dont use remote commands at all , as not all have the same functions available .
have a look at how I use pcgedit commands .
Editing the commands of the buttons on the DVD menu?
By rone in forum Authoring (DVD)Replies: 24Last Post: 18th Jun 2011, 05:35 -
PgcEdit v7.4: a free DVD commands editor.
By r0lZ in forum Latest Video NewsReplies: 61Last Post: 22nd Mar 2010, 15:54 -
TMPGEnc DVD Author 3.0.5.149 - subtitles with italic commands
By lienny in forum Authoring (DVD)Replies: 9Last Post: 20th Jan 2009, 21:27 -
DVD VM Commands
By TonitoDJ in forum Authoring (DVD)Replies: 1Last Post: 24th Nov 2008, 10:55 -
Adding remote nav commands durring DVD video playback?
By Scav2003 in forum MacReplies: 3Last Post: 13th Mar 2008, 15:41
