I have a documentary divided into four parts, three of them work but i cant get the 4:th to work, i dont have audio or video, and when i press play nothing happens but it shows a movie lenght of 46 mins in WMP.
Heres a picture ive taken when i loaded it into G:Spot if it helps.
You are in breach of the forum rules and are being issued with a formal warning. No warez.
/ Moderator Cobra
Closed Thread
Tjena
Hi-
I'm not sure why it says DIV4 and DivX 3 Fast Motion if it's supposed to be XviD. Do the others also say that? My first suggestion would be to use a better player to play it (i. e., any player other than WMP. Try Media Player Classic or VLC Media Player). My 2nd suggestion would be to change the FourCC to XviD. There should be a FourCC changer included with the XviD Codec. It's called AviC.exe.
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 11:52 -
Encoding ( hardsubbing) doesnt work with ffdshow
By lovemusic in forum SubtitleReplies: 2Last Post: 5th Mar 2008, 14:37 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 10:21
