    Nov 2005
    i cant rip sky high every time i try to burn to dvd it says invalid data in file dvd fab decrypter\dvd\video_ts vts_01_1.vob i can copy it to hard drive but i cant shrink it using dvd shrink thats as far as i can go
  2. Use VobBlanker on the HD copy. Copy to a different directory. Then you should be able to use shrink. If not, use IFOEdit first.
    Aug 2001
    Boondocks, MT
    I first used DVDFab to the hard drive and then Voblanker to a different part of the hard drive and then DVDShrink to another hard drive and to finish the project, burned with Nero. I know that this is a lot of work but it worked for me. Hope this helps you
  4. I used DVD Rebuilder and CCe with no problems
