Results 1 to 11 of 11
  1. Does any of this app. support AC3 audio to make a DVD?
    Toast 7.0.1
    iDVD 5.0.1
    DVDSP 4
    Sizzle
    Or should I encode the audio in mp3?
    Anyone knows an app. that supports AC3 in a .avi to make a fine DVD?
    Cheers lads,
    M.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    DVDSP, whether version 3 or 4, does.
    as for your .avi with ac3, as long as the .avi has been
    encoded with a codec you have that Quicktime likes,
    DVDSP should be able to handle the import in directly.
    If DVDSP refuse to import the video, chances are it
    doesn't like the codec.
    You could bounce the .avi through DIVX Doctor II
    which would cause it to "dump" the .AC3 track, but "re-assign"
    the .avi's codec to 3ivx. this would produce
    an .avi with no sound, but you have the .ac3 track still
    be available seperate.
    DVDSP likes 3ivx, I use it all the time.
    You could then import the .avi into DVDSP, import the
    "dumped" .Ac3 into DVDSP, and with DVDSP set to do
    Background encoding, should be able to create your
    episode DVD in no time.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. Thanks terryj!!!
    I am not used to work with DVDSP, this process that you suggest will work with 2 o 3 .avi files with ac3 audio?
    Can do this background encoding with each file?
    Thanks again,
    M.
  4. Member terryj's Avatar
    Yes, and Yes.
    Repeat the steps for each .avi.
    With Background encoding set in DVDSP's preferences,
    each .avi will encode in the background after importing.
    the .AC3 tracks are already compatible upon import.
    Urban Mac User
  5. Thank you very much.
    Starting the job now.
    M.
  6. I tried to use Doctor II but I got this log:
    Doctoring AVI
    FILE = /Volumes/Varios/LOST2HR/lost.s02e08.hr.hdtv.ac3.5.1.xvid-tvd.avi
    AVI contains an AC3 track!
    ERROR: Could not open audio track
    FILE = /private/var/tmp/folders.501/TemporaryItems/auds.tmp
    ERR = -2048, noMovieFound
    ERROR: Building Repaired AVI
    ERROR: Doctoring AVI
    ERROR: Error while Doctoring
    I do not know why is that, i have selected differnt folders to save the doctored file and always got the same error, evevn with different files.
    I just get an audio.ac3 file.
    What I am doing wrong? any clues?
    Thanks for your help,
    M.
  7. Toast can create DVDs with AC3.
    Toast can convert AVI to DVD... but if the AVI (which is usually DivX in disguise) has an AC3 soundtrack instead of more standard MP3 you will need the free QuickTime component which decodes AC3... the gotcha is that QT 7.0.2 broke this and other Variable Bit Rate decoders... so if you are running QT 7.0.1 you are safe... but anything higher, you're going to have to wait for an Apple fix.
    And yes, I'd be remis not to point out that MacMall is selling Toast 7 for $39 after rebates through December 9.
  8. I am running QT 7.0.3, so should I go back to QT 7.0.1?
    This "degrade" will allow me to make DVDs on Toast with .avi files with AC3 audio?
    Thanks,
    M.
  9. Member terryj's Avatar
    Doctoring AVI
    M.
    shorten the name of one of the files to LOSTe1.avi
    then try it.
    Everything up until the 2048 error is right.
    DD2 is dumping the AC3 track into a seperate file,
    but then the -2048 error happens on the video.
    try this suggestion by digisam, five posts down
    here.
    Urban Mac User
  10. Thanks terryj, I have done it with files with shorter names and the same problem, so I am going to try the suggetion of digisam (i am reading it and trying to understand it).
    Thanks for the link.
    Cheers,
    M.
  11. Member terryj's Avatar
    cool.
    let me know if you get stuck my friend.
    Urban Mac User
