When I try to use thw VirtualDub to capture. I got Error 418: Capture device was not detected. Can anyone help?
Try doing a search on the Forums for a file called 'wrapper'. I had the same problem and this worked for me...good luck!
HD80E capture device problem
By gbsatti in forum Capturing and VCRReplies: 40Last Post: 9th Aug 2012, 14:09 -
VirtualDub Capture Pin problem.. (EasyCap) [SOLVED]
By muzzmikkel in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2012, 11:05 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 17:35 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
