I would like to get Pro Logic II sound from my Gamecube. But unforunately, my receiver doesn't have any Video IN connections, so I have to connect the Yellow composite cable straight to the TV; this prevents me from connecting the RED/WHITE composite cables to the receiver because they can't reach.
So, my question is... if I have the Gamecube connected through RED/WHITE composite cables straight to the television, and have my receiver set to TV/AV, will I be getting Pro Logic II sound?
Thanks!
first of all, the rca cables are connected together only by a thin peice of rubber..if you pull the yellow away from the red and white it will seperate along that thin divider until you have enough seperation to get the red/white to your receiver.
your second option would work..but you are going to decrease the quality of the audio considerably by going through your tv and then to the receiver...the fewer links in the chain the better :P -
Thanks for the reply!
Yeah, I've done that before. However, the cables that I'm using to connect my Xbox/PS2/Gamecube (universal s-video cable) to the television, have a thick plastic ring around the cable; it prevents me from separating the inputs.
(How annoying, right?)
I guess I'll just have to deal with the quality of the audio degrading... I don't want to give up S-Video.
thats understandable..you may also want to try getting some good RCA extension cables and running them straight to your receiver..that would give you the slack you need and may still sound better than running through the tv...
Dolby Pro Logic IIx encoder
By nateo200 in forum MacReplies: 4Last Post: 4th Feb 2012, 13:45 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 14:35 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 15:08 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
