Does anyone know how to go about this? I can convert a single VOB from PAL to NTSC but what if I want to convert the entire DVD (but I can do without menues etc.) What's the best (and easiest) way to make an NTSC DVD out of a PAL DVD? I have ripped the PAL video to a VIDEO_TS folder on my hard drive.
Thanks!
Patrick
You want to use the DGPulldown method.
Here is a thread that should get you going: CLICK HERE
If you have any questions feel free to ask.
Yes, I am in the learning proces of the DGPulldown method to convert 25 fps avi or PAL dvd into ntsc dvd with original 5.1 audio.
What isn't clear to me is: at the end with remuxing the end-resulting m2v file with the original AC3 stream, do I have to do this in eg. MuxMan and fill in the audo delay value or in TDA, that imo, has no delay correction?
I have a (source=avi) AC3 stream with 16 ms of delay, so I can't really check it on my pc. Is there a general rule to use/not use the delay?
Thanks in advance
You will not notice a delay of 16ms anyway. I think the cut-off is roughly 100ms before you can see a difference.Originally Posted by Ennio
- John "FulciLives" Coleman
P.S.
You can also use AC3 Delay Corrector to adjust the delay"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
What happened to Procoder Express?
By lordsmurf in forum Newbie / General discussionsReplies: 11Last Post: 26th Feb 2008, 00:54 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26
