    Nov 2005
    Question from a newbie. Just bought a LITEON LVW-1101HC1 DVD recorder. I want to copy some purchased VHS tapes to DVD for my kid's portable player. I keep getting a message "Protected Content" and it will not record. I assume because of copyright. I tried an old VCR--no help. Tried making a VHS copy and recording from that--no help. Any way to get around this? Do I need some kind of converter? Thanks in advance.
    --John
    Nov 2005
    Thanks. Is this the best solution? I was hoping not to have to buy another box, but maybe this is the best way. I appreciate the info.
  3. There may be cheaper devices but I know this one works since I own one myself.
  4. [ uncledee8 ]
    There are many devices out there some work to a fashion some are just bummers. I know Iv'e been there
    You have a liteon unit that is or may be a step in the right direction, I dont know if your unit can be hacked,
    Check these sites
    http://www.techolio.com/forums/phpBB2/viewforum.php?f=7&sid=172de8224623503620923db1d0b52362
    http://ncc2315.com/ilo/
    While ilo is noted ilo is liteon and the site covers liteon and refers to other good sites
  5. Banned
    Sep 2003
    Hi Guys,
    Facing same issues as posted here, I recently bought a hardware modified DVD recorder, the Liteon 5005x, with a built-in copy protection remover. I'm very happy with the purchase. Records premium channels or any commercial VHS to DVD.
    LINK DELETED
    Ocean
    Continually posting the same message about the same site and product is considered SPAM. If you want to advertise here, contact the administration. Moderator redwudz
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator redwudz
