Can anyone tell me what the best program to capture VHS into my PC straight to an mpeg2 dvd compliant file with the best picture quality or least quality loss. I am capturing using a Canopus ADVC300. I have WinDVD version 2.0 which is used to capture into this format and the picture quality was kinda poor. I did a search on the forum, buy was unable to find a program.
Thanks,
Lonn
You can use Mainconcept encoder for DV to MPEG-2 directly. It needs quite a bit of computing power and you will likely have to use the buffer option. Quality? You can only do so much with that quick of an encode, but give it a try.
(VHS to DVD) AVI filtering vs. straight MPEG; Post your comparisons
By darito in forum Capturing and VCRReplies: 37Last Post: 2nd Apr 2012, 05:26 -
Convert old VHS-tapes to mpeg2?
By Mållgan in forum Capturing and VCRReplies: 10Last Post: 19th Nov 2010, 08:30 -
Recording straight to MPEG2 PAL Video using a Hauppauge HVR-1800
By 3_2_DVD in forum Capturing and VCRReplies: 7Last Post: 22nd Sep 2009, 12:28 -
vhs to mpeg2
By arcticstudio in forum Video ConversionReplies: 5Last Post: 8th Nov 2008, 09:28 -
Anyone doing Straight D-VHS to H.264 Capture + Post Editing / Cleanup?
By bradeso in forum RestorationReplies: 4Last Post: 22nd Apr 2008, 04:01
