I have taken out each title with dvd shrink then used TMPGEnc and add eash title individually, then edit, created a menu and soutputed to HDD. The movie is still to larger of dvd+r and now I want to shrink it with dvd2one.
I have dvd2one V1.4.0. I have used this many times for movie only back ups and used the constant ratio. My question is what would I use for a cartoon sereis dvd?
Full disc or movie only?
Constant or variable?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
Originally Posted by Denvers Dawgs
Also did you know you could take out needless repeated episode intros/ending credits, to save on more space? Pretty easy for me with dvdremakepro.
Variable was also the very first compression engine on DVD2One,with constant added later on. Pretty sure the latest version of DVD2One only uses variable compression and does not include the option for the constant engine anymore.
And full disc or movie? I always do full-disc as the menus are cool and do not take up much space anyway(you could even downsize the menus in shrink if you wanted). -
Well since you just spent an hour using shrink to take out the titles you wanted, then built yourself a dvd with a quality menu. You probabaly want to do a Full disc, so you can kepp the menu YOU RETARD!!
Any ideas on the Constant vs Variable Compression Mode?What We Do In Life, Echoes In Eternity.... -
well someone posted just ahead of me thanks for the info
Its only in re-author mode that the menus are lost.Which i rarely use. -
Oh well shiver me timbers..... I never new that. thanks for the info.
Since I have already done a new menu, mind you a pretty sweet on if I do say so myself. I'll stick with what I have created for this series, but next time, I'm trying shrinkWhat We Do In Life, Echoes In Eternity.... -
Here is what I came out withWhat We Do In Life, Echoes In Eternity....
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 22:34 -
Trouble with new disney dvd _ cartoon Phineas and Ferb
By kriswoodzmeg in forum DVD RippingReplies: 3Last Post: 30th Aug 2010, 10:27 -
best way to rip cartoon dvd's
By earto in forum DVD RippingReplies: 0Last Post: 6th Oct 2008, 05:13 -
Proper path to get Divx cartoon to DVD with menu
By Krazykevin in forum Authoring (DVD)Replies: 5Last Post: 17th Oct 2007, 21:17
