I would like to ask somebody to please explain to me how to use premier 6 to encode .avi files so i can make vcds. I got my copy of premier 6 with no instructions so any help will be appreciated
Douglesh is right. If your purpose is only to convert AVI to VCD, use TMPGEnc.
If you however want to use multiple clips and some video effects with Adobe Premiere, and wished to output to VCD Format,you could use the bbMpeg plugin ( http://members.home.net/beyeler/bbmpeg.html). I have not been personally satisfied with the quality bbMpeg gives.
A better option would be to use the AVISynth premiere plugin ( http://www.math.berkeley.edu/~benrg/avisynth.html ) and frameserve to TMPGEnc.
For more info check (www.rmvos.nl)
If you are new to Adobe Premiere and wish to know more, visit the Adobe site and forums.
Try this (http://www.adobeforums.com/cgi-bin/webx?14@@.ee6b372). Login as a Guest. Check out the FAQ. You should be getting a lot of info there.
Best of Luck
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 23:01 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 13:57 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 22:55 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 11:29
