I just bought a Liteon 5115 DVD recorder and burned my first DVD (16x write speed DVD-R) from a VCR hooked up over the Component video hookups. My problem is that when I play the newly burned DVD in my Toshiba SD-v392SUA DVD player it plays fine until I fast forward. After coming back to "play" there is no sound. HELP!
Sorry my actual post disappeared. I have had similar trouble with -R discs but resolved the problem by switching to +R discs. I've had the same pattern with RW, as well.
Good Luck
VictorV. Abrego -
Do you have the same burner and player?? Did the sound only go away when you did fast forward? With mine, the sound will come back after you turn the DVD player off and back on. Thanks in advance for your reply
Progressive scan output from Liteon 5115
By Regor21 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 7th May 2010, 21:26 -
Playing Region Free PAL DVD On Soon To Be Hacked Toshiba HD-A2 Player??
By akthmps in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2009, 14:19 -
Write error problem with mpeg streamclip
By mattcourage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Nov 2008, 11:57 -
Toshiba D-R400 QUestion on Playing Back AVIs
By shaggy2002 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th Nov 2007, 15:09 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 08:50
