hi all i ripped a dvd using dvd decrypter and than used autogordiansknot to convert it to an avi. i now want to convert it to vcd using tmpgenc but i cant because tmpgenc wont take the audio so i download besweet and belight but they will only take the ac3 audio and i don't know how to extract the audio as i have already tried it using virtualdubmod and tried to save the audio stream as wav and i have also tried to demux it but both have failed help would be greatly appreciated. tanxs
If in doubt, Google it.
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm might assist (don't use virtualdubmod, use another variant).
If in doubt, Google it. -
use vobedit instead to demux the audio stream .
Open first vob of title , choose demux , sellect audio to strip , choose demux complete title set , and go , your done .
Virtualmod requires a specifically writen script , so it can concat the files one after the other , something similar to avisynth scripts using directshow inputs .
Dvd to avi or vcd
Use dvdx2.3 www.labdv.com/dvdx , dose both and more . -
ReJig is also good (and easy to use) for demuxing DVD streams.
/Mats
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
