hi... i was wondering if i copy more divx movies on a dvd how can i make the dvdplayer read the subtitle?
i mean i have some that get read some dont... very few get read....
srt, txt, sub work on dvdplayer?
thanks
Results 1 to 9 of 9
There is more to life than you see!
i ment if i have wedding.avi (xvid) and wedding.sub(srt)
how can i make the sub play on the dvdplayer?There is more to life than you see! -
It depends on the dvd divx player...but it usually works like naming the files like video.avi and video.srt and you press the subtitle-button on the remote when you play the video. Search for the dvd player using google and see if you can find some info...or check the manual if they mention anything about subtitles.
or make xsubs...very complex but it should work on many divx players, https://www.videohelp.com/forum/viewtopic.php?t=267432&highlight=xsub -
thats the problem i encountered a while ago, some read srt fine some dont. Follow the link posted by Baldrick and read the guide hereOriginally Posted by [.Q.
http://projects.gdion.biz/guides/dmfwithxsub.html
with the xsub format your subs will look the same and be in the same position on any divxcertified player.I love it when a plan comes together! -
you can find the latest version of srt2bmp(1.0.4.20) here
http://polo.faenquil.br/~valerio/srt2bmp/srttobmp.rar
youi will need to download the fuse tool as well from here
http://download.divx.com/labs/Fuse02182005.zipI love it when a plan comes together! -
I made an small free application [avisub] that can add up to 3 subtitles without reencoding the avi.
Take a look here :
http://www.trustfm.net/divx/SoftwareAviSub.html
As input subtitles supports :
srt
sub txt / microdvd format
son
Outputs:
An *.divx file [subbed avi]
I also added the gabest's tool subresynch so someone that have an vobsub can convert it to son and then load it to avisub in order to get an *.divx avi with embed subtitles.
Is has been tested with success to these divx players :
Contel DVR2000
Digitrex JDP500D
LG9900
Philips DVP720SA
Samsung HD850
Hope you like ite !
if you already have the subs in srt format, divxmux can take the files and form one divx media file that should be compatable with any divx certified device.......grab it from labs.divx.com (mind you, its a command line tool though, so if your not familiar with command line........)
whitejremiah thats right but avisub makes srt->xsub [visual] convertion in order to not have problems with codepages,frirmware upgrades etc
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 06:15 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
![Send a message via Yahoo to [.Q.]](images/misc/im_yahoo.gif)
