    Jan 2004
    Iowa, USA
    I downloaded AutoGK v2.20 Setup and read the website tutorial, and it says "XviD 1.x.x is included with the main AutoGK Install Package." So, what happens if/when I install AutoGK v2.20, does it's version of XviD overwrite/conflict with the later version of XviD (v2.1) I already have installed on my PC? Or has the tutorial not been updated?
    USA
    From the 'Tools' page to the left for version AutoGK 2.18, the latest version listed being 2.20:
    - XviD build of 16/09/05 included
    So I would assume it's using a fairly new version of Xvid.
    Dec 2004
    Australia
    No way you have v2.1 installed. Newest version in the cvs is v1.2 and it really isn't any different currently than 1.1.x.
    The build included with AutoGK is my compile from when ever it was released along with a modified VfW front end to include additional MTK profiles. It will over right any XviD build installed.
    Jan 2004
    Iowa, USA
    Well, I thought that's what I have installed... when I select "XviD video compression" in VirtualDubMod and click the "About" button, it says "Core version 2.1". I couldn't find a reference to a version number anywhere else, so if I misunderstood, I apologize.
    So the upshot is, if I install AutoGK 2.0, then I'll get the latest version of XviD, which will overwrite what I currently have (v?.?), and everything will still work correctly with VirtualDubMod?
    Dec 2004
    Australia
    Sounds like maybe you have an old devapi-3 build installed. I would suggest uninstalling it first since it used different files (xvid.dll and xvid.ax instead of xvidcore.dll, xvidvfw.dll and xvid.ax).
    You won't get the latest, but it will be fairly recent.
    Jan 2004
    Iowa, USA
    Here's some more info from my version's "About" screen:
    July 16, 2003
    and below the web URL is:
    (Vanilla CVS Build)
    GPL's MPEG4 video codec demonstration.
    For educational purposes only.
    So, any idea what version I have? But the bigger question is, if I install AutoGK 2.0, will it's version of XviD still work correctly with VDubMod (after uninstalling my version of XviD first)?
    Dec 2004
    Australia
    2003 was a long time ago. Basically you have a pre 1.0 build.
    Jan 2004
    Iowa, USA
    OK, thanks for your help.
    2003 wasn't that long ago
