Hi,
I've been playing around with lots of settings in TMPEG, So to get get the best final output Mpeg2 file for DVD-R. The best i've come up with is a slightly modified template of this pwp.netcabo.pt/0165394101/TMPGEnc_Template.html .
The thing is, that, to encode a 3 hour Avi in this sort of template will take me 72 hours constant. I tried encoding 10 mins 47 secs. and it took 4.01.39 hoursso in my calculations its 72 hours in total.
As this is rather ridiculous i'm thinking of changing the way i'm going about this.
1.) Twin Athlon Mp Processors. cost £400 approx
2.) Hardware Mpeg2 encoder. cost £650 approx
3.) Cinema Craft. cost ...????
4.) Overclocking pc??
Current System
Win XP Pro
1.4 Athlon 266 FSB
Coolermaster HHC 001 Delta Heatpipewww.coolermaster.co.uk/hhc-001.htm
Asus A7V266 Mainboard
512 DDR Memory
Asus 8300 G-Force 3 Deluxe
Pioneer DVDR-AO3
40 Gig IBM "Ericson" IDE 7200
60 Gig IBM "Ericson" IDE 7200
Customised Case inc. 6 Fans, LCD, Temperature controlled
www.totallycustomised.com
FireWire
100 Mb Network Card
Any advice will be greatly appreciated.
Thanks.
"Smoke Me A Kipper, I'll Be Back For Breakfast!! :D
I've only been burning xvcd's since the summer so I don't have a voluminous experience base, but I would go the twin-AMD route. I use tmpgenc 2.02, and I got a dual-1400 not long ago and it makes a sizable difference. It's enabled me to reasonably experiment more with higher bitrates and quality tweaks with the time savings.
'Course, it also helps that I have a couple of hard drives in portable firewire carriages from ADS that I use to shuttle files between the computer I use to capture/trim converted vhs-to-avi footage and the dual-proc that I tmpgenc/burn xvcds.
never used cinema craft, not drawn to hardware encoders
my two cents -
Thx for the reply,
Q.) Do you know the difference in timescale between using a single processor, compared to duel?
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 24th Aug 2010, 00:17 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 12:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
