I redited audio, before remixing should I split the channels into left and right or after
Too vague. Can't help without further info...
Give us more particulars:
What filetypes/streams/channels did you start with?
What filetypes/streams/channels do you want to end up with?
What applications are you using?
Any hardware constraints?
Are you talking about ReMuxing? ReEncoding? or just ReSaving?
Scott -
I'm talking about resaving the work. No hardware contraints, using wav. I'm using sound forge and audacity I want a surround effect. not pure 5.1 but close and how can I have a stereo\mono file. Is that how it's done in 5.1
Well, since neither SoundForge, nor Audacity natively support multichannel files, the options are a little more limited.
Sounds like what you want is to generate a psuedo-5.1 surround mix, upconverted from an original stereo mix, right?
Well, there are methods to doing this, but they're involved so I will just direct you to do a search of this site. Try "remix" and "surround"...
HTH,
5.1/6 Channels to 2 Channels?
By tmac2085 in forum AudioReplies: 24Last Post: 10th Nov 2011, 20:54 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07 -
Two mono channels
By Digiface in forum AudioReplies: 4Last Post: 13th Jan 2008, 13:14 -
QAM channels
By sorinicu in forum DVB / IPTVReplies: 7Last Post: 25th Nov 2007, 23:07
