i'm looking for a dvd player to play homemade vcd and svcd. after doing a little research, i've determined that the pioneer dv-333 is probably my best bet. however, i have been unable to find the information on what type of outputs it uses. I know my television cannot use component video, and i'm not quite sure about s-video. will the dv-333 output with composite or coaxial wires? thanks for any help.
I have the dvd333 it kicks ass I rip dvds and burn them onto vcds they all play fine I found other players have problems sony is one. My tv has only coaxial input i use a RCA Rf modulator COST 20.00 at good guy or even radio shack. buy the dvd333 you can't loose it one of the best if not the best.
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
Help with simultaneous video outputs
By Rob #3 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th May 2010, 21:53 -
Activating PC- DV outputs
By 1234567 in forum DVB / IPTVReplies: 13Last Post: 19th Feb 2008, 17:43 -
Compaq PC133U-333-542-A 256MB, SYNCH, 133MHZ, CL3?
By rkr1958 in forum ComputerReplies: 3Last Post: 21st Oct 2007, 18:54 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
