  1. Member Gritz's Avatar
    Feb 2003
    I have a customer that has a 3.2 GB Fujitsu HD which has Ontrack Disk Manager embedded. They don't care about the old Fujitsu, but would like to upgrade to a larger 40 GB hard drive on a different system, but ...... they want me to "duplicate" this old hard drive to the new one. The new system will not need the "Ontrack" stuff, and I'm thinking if I do a Norton Ghost copy this will also be copied and possibley screw it up.
    How can I eliminate the "Ontrack" without doing a new install? Or is it possible.
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
  2. Banned
    Apr 2001
    Calgary, Canada
    Did you read this?
  3. Member Gritz's Avatar
    Feb 2003
    Hilljack,
    No, I hadn't. I had gone to Fujitsu's site and the only info I could find stated I would lose ALL data. I saw also that Fujitsu no longer offered Disk Manager for free, but I did a Google search and I found where I could download ver 9.52.
    Thanks much Hilljack for the information .... I printed it out, and I'll be using it. I really appreciate.
    Gritz
