amusing Studio9 to make my movies into PAL from NTSC, it works fine but the whole way though the movie from start to finish the video jumps but the audio plays fine without any problems.
its not my dvd media as they have worked berfore on my player with out anyproblems.
anyone got any ideas?
cheers
joey
Before you state that it's not the media, make sure that you run a CDSPEED disk quality scan and see. All brands of media, including Taiyo Yuden and Verbatim can and will have bad media from time to time, although it is very rare for the high quality stuff.
Run a quality scan on your media, and please post what brand and media id you are using. If the media test is good, it could be changes to your setup, such as codec's, software upgrades, windows upgrades, firmware upgrades.Rob -
I think the problem is the 29.97fps->25fps conversion,I would try another encoder.
did the CDSPEED disk quality scan and everything got a green light. so its not that.
MOVIEGEEK : what encoder do you suggest. ave tryed ProCoder 2 and now Studio 9.
EDIT: i dont think its the encoder cus the file plays fine on my pc both in mpf format and as VOB files from the VIDEO_TS folder. and the dvd check out fine.
wtf is going on
someones gotta have a clue -
As a user of video studio 9 , and having done many conversions without problems , it may simply come down to your home player having an issue .
Use a good head cleaning kit , and see how it gose .
Cheap home units use cheap len's , and these wear out at around 2-3 years , depending on how often they are used .
You could also try the disc's in a friends unit and see how they perform .
If they work well there , then you know where the problem lies .
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 01:51 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
can you help ...ulead...mpeg... blocky
By newbie44 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2008, 07:43 -
Ulead crashing
By chewie8008 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 09:57 -
Problems with Videostudio9
By Tamberam in forum Newbie / General discussionsReplies: 8Last Post: 11th May 2007, 01:01
