ok, I propose here that people that have tried this setting let know what is the best qmin in there opinion.
Note: the lower the qmin, the higher the quality.
For what I saw, qmin=22 is too less. I get bitrate of around 1700 very often, even if the video is only 720x304 pixels.
qmin=30 is definitively too much, I get 300kbps for a 720x448 video.
qmin=26 seems ok, but I'm not yet finished with the encoding. And I have to test qmin=27 and qmin=25 also. Of course it will depend of the video, but still it could be nice to know what people are using...
cheers,
kaz
So it seems that qmin=26 gives me here a global PSNR of 40, which a bitrate of 800. Which is not bad at all.
I didn't talk about size. I just talk about bitrate. I just said that an average of 1700kbps for a 720x304 video is too much. That's why I'd like to have some values here, in order to compare.
BTW, is there a direct relation between the PSNR and the qmin?
The point of constant quality mode is to encode the movie with the specified picture quality. The encoder will use whatever bitrate is needed to achieve the desired quaility at each frame. If the video is dark, has little detail, and little motion it will require few bits. If it is bright, has lots of detail, and lots of motion it will take lots of bits. If you encode 10 different movies at the same quantizer setting you will get 10 different average bitrates.
Best h.264 setting for optimal size/quality with handbrake.
By frickfrock99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 02:09 -
help converting 2Tb of videos to H.264 (size/quality/tools)
By Prophes0r in forum Video ConversionReplies: 3Last Post: 13th Aug 2009, 23:05 -
DV to H.264 conversion with emphasis on quality
By bpoe in forum Video ConversionReplies: 15Last Post: 26th Apr 2009, 10:43 -
How to convert AVI to MP4 using H.264 encoder without losing video quality
By VidHunter in forum MacReplies: 0Last Post: 21st Dec 2007, 01:04 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
