Hi,
I need your help, since I tried so many conversions and procedures:
Well, I have a DVD format (Audio and Video folders).
I would like to edit it in Premiere. To which format I should convert it?
I tried so many formats but couldn't succeeded (XVID / DIVX / MPEG2 etc.)
What should I do?
Regards,
Uriel
I am assuming you mean an Audio_TS and a Video_TS folder.
First, the audio_TS folder is a furphy and can be ignored. It has no baring on DVD video.
Premiere doesn't like editing mpeg video (which is what you get from a DVD). You can look at the mpeg editing plugin from mainconcept to improve premiere's mpeg editing, or you can demux the video and audio from the VOB files (look up demuxing tools for options), then use virtualdubmpeg2 to convert the mpeg to DV, which Premiere definately prefers.Read my blog here.
Premiere Pro CS5 not detecting correct footage duration
By Eccen in forum Video ConversionReplies: 13Last Post: 23rd May 2011, 23:44 -
Correct Presets in Premiere CS4 and AME?
By 3DHDAnaglyph in forum Authoring (Blu-ray)Replies: 13Last Post: 26th Oct 2010, 08:34 -
Audacity doesn't load wav from Premiere
By Instant Martian in forum AudioReplies: 2Last Post: 12th Jun 2010, 11:26 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Hoe to create a DVD menu with link to AVI files
By OggO1984 in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2009, 16:01
