Hi.
Have any of you ever ordered tmpgenc online using their website order form.
If so is it safe?
I wanted to check as the ordering page doesn't look quite as well made as the rest of the site.
Results 1 to 16 of 16
No problems here. I ordered TMPGENC DVD Author for myself and MPEG Editor + Express for a customer. There order form is typical of online order forms and I haven't had my credit card misused since ordering almost or over a year ago.
In my opinion there shoud not be any problem in downloading TMPGEnc products if you are downloading from http://www.tmpg-inc.com
Same here ... No problems ordering on-line from http://www.pegasys-inc.com
3 years ago: TMPGEnc Plus Encoder
2 years ago: TMPGEnc DVDAuthor v 1.5 w/ac3 plug-in
1 week ago: TMPGEnc DVDAuthor v 1.6 (Upgrade for $11) -
I have purchaes the entire line of TMPGEnc oriducts over the years and have never had a problem. TMPGEnc also has an agreement with TSunami. They offer several programs close to the TMPGEnc line. They all work very well and once again no credit card problems.. I considered these companies to as good as Newegg.
Originally Posted by orbitmonkey
The AC-3 plugin for TDA is not free, it costs $29. You can find information about it here: http://www.pegasys-inc.com/en/product/tsp_ac3.html
Go to http://www.pegasys-inc.com/en/shopping/tsp_ac3_d.html to buy and download it.
Once the plugin is installed, it will be recognized automatically by TDA. -
So I buy it from http://www.pegasys-inc.com/en/shopping/tsp_ac3_d.html, and install it? Do I install when TMPGEnc is open or before I use it?
What We Do In Life, Echoes In Eternity.... -
I just bought and downloaded TSUNAMI DVD Author PRO $99.00 and am very happy with it. It is the easiest authoring program I've found to use, & does everything I need. Supports Dolby Digital Audio (2ch AC-3). Dual Layer 8.5 gig support. Can preview your move with the simulator before you save to harddrive or file, or write to DVD. It has a wizard to walk you through.
If you want to check it out here is the URL:
http://www.tmpg-inc.com/product/tdap.html
Lonn
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 15:30 -
TV Safe Colors ?
By Mike99 in forum Authoring (DVD)Replies: 31Last Post: 13th Nov 2008, 03:01 -
Watch movies online with other online also at the same time?
By Ghtpua in forum Software PlayingReplies: 5Last Post: 11th Feb 2008, 13:02 -
About TMPGEnc judging field order
By jmayme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 13:56
