    Oct 2005
    USA
    OK, installed new version of ffmpegX. Installed new binaries. Renamed my hard drive not to have spaces in the name (!). Tried to install new reallib files, but when playing the .rmvb I want to convert, I GET NO SOUND. Therefore use the older, "stable" version of the reallib files. This time, .rmvb file plays with no problems if I hit the Play button after dropping into source location on front panel of ffmpegX.
    ffmpegX by default now correctly picks mencoder in the right video format (640x480, 24 fps). The selected format is AVI DivX. Did not change ANY options from default settings. Hit Encode.
    Reproduced here is the start of the log: A LOT of error messages, then many "Skipping frame!" entries.
    I REALLY, REALLY would like this to work....
    Thanks.
    Encoding started on Thu Dec 1 20:51:07 PST 2005
    MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
    Mac OSX static build for ffmpegX
    AltiVec found
    CPU: PowerPC
    success: format: 0 data: 0x0 - 0x130c3031
    REAL file format detected.
    Stream description: Audio Stream
    Stream mimetype: audio/x-pn-realaudio
    Stream description: Video Stream
    Stream mimetype: video/x-pn-realvideo
    Stream mimetype: logical-fileinfo
    VIDEO: [RV40] 640x480 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:11 fourcc:0x30345652 size:640x480 fps:24.00 ftime:=0.0417
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so, 1): image not found
    Opening audio decoder: [realaud] RealAudio decoder
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so'
    Read the RealAudio section of the DOCS!
    ADecoder init failed
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so.6.0'
    ADecoder preinit failed
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so.6.0, 1): image not found
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.bundle/Contents/MacOS/cook'
    Audio codec: [21] 32 kbps Stereo Music High Response - RA8
    Audio bitrate: 32.041 kbit/s (4005 bps)
    AUDIO: 44100 Hz, 2 ch, s16be, 32.0 kbit/2.27% (ratio: 4005->176400)
    Selected audio codec: [racookmac] afm: realaud (Mac OS X RealAudio COOK)
    Opening video filter: [expand osd=1]
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): image not found
    ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=640 h=480]
    Opening video decoder: [realvid] RealVideo decoder
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
    Read the RealVideo section of the DOCS!
    VDecoder init failed
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
    DOCS!
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
    Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
    Forcing output fourcc to 58564944 [XVID]
    Building audio filter chain for 44100Hz/2ch/s16be -> 48000Hz/0ch/s8...
    Building audio filter chain for 44100Hz/2ch/s16be -> 48000Hz/2ch/s16be...
    VDec: vo config request - 640 x 480 (preferred colorspace: Planar I420)
    VDec: using Planar I420 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (640x480 fourcc=58564944 [XVID])
    Writing AVI header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    Skipping frame!
  2. It looks like it is encoding, is an output file being generated?
    Oct 2005
    USA
    OK, I have to retract.
    It works. I was put off by the too many error messages. An AVI file was in fact generated, and it looks OK.
    It takes about two hourse for a 1h video, and the size doubles from ~350 MB to ~700 MB. I will experiment with other formats.
    Those error messages are extremely misleading.
  4. These messages are printed because mencoder tries lots of decoders until one which works is found, and then encoding starts.
