    Aug 2005
    san diego
    its been a few months since i have ripped a dvd and burned it.
    my set up:
    dvdshrink i think its version 3.2
    and the nero software that cvame with my liteon internal burner.
    problem one: i inserted a dvd and dvd shrink analyzed it and began the backup. it took the normal 45 minutes or so to do its thing. a window pops up that says the backup was complete. i should see a winodw that says insert a blank dvd and then burning happens......
    -un installed dvd shrink
    -downloaded a new version and installed
    -still same thing
    -uninstalled nero
    -downloaded version 7
    -found out that nero 7 and dvd shrink dont work well
    -installed nero oem suite that came with dvd burner
    -still no joy.
    at this point it should be back to the setup i had months ago that worked! no joy!
    so i was able to get the dvd uploaded to pc and stored on c drive. i figured i would try to use nero to burn from c drive. it loads, shows about 4464 MB and i click finished and go to the next screen where it has burn settings but my burn icon is not highlighted.
    cannot burn with dvd shrink and nero combo.
    any suugestions?
    kyle
    Northern Territory
    At the moment, the name of your backup dvd will have a lot to do with what is going on out there in DVD land.
    Look for other posts on "Madagascar" etc and see what has been going on.
  3. See the Madagascar post I go to the end were I reply you will see how too do it.
    "Man who walk through airport turnstile backwards
    going to Bangkok."
    Aug 2005
    san diego
    at the moment we are using memorex dvd-r.
    thanks
    kyle
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Is it possible that you selected "Hard Disk Folders" as your output target instead of your burner ?
    Many believe it is better to use the freeware DVDDecrypter to burn from within DVDShrink anyway. It doesn't bother me either way, as I use the DVD-Video template in Nero Express for all my DVDs.
    And FWIW I'd avoid Nero 7 like the plague ...... at least until they're up to version 7.3 or thereabouts. For now, you might do a google for "Nero clean tools" to get rid of 7 properly, and then reinstall the version that came with your burner.
    If in doubt, Google it.
    Aug 2005
    san diego
    yes my dvd reader is also the writer.....
    soi rip to c drive and copy from c to E when rip is completed
    kyle
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    so i rip to c drive and copy from c to E when rip is completed
    Unfortuantely that doesn't really answer my question
    If you selected "Hard Disk Folders" as your target device, DVDShrink will send you a message on the screen saying "Backup complete". It is then up to you to burn it yourself in whatever burning software you see fit.
    However, if you select your burner as the target device, DVDShrink will do it's thing, and then fire up Nero, and co-ordinate the burning process for you. I'm pretty sure that it doesn't give you the "backup complete" message until the burning process is finished.
  8. Banned
    Feb 2005
    USA
    DVD Shrink will give you a message that the backup is complete even without burning a disc. If you write the output from shrink to hard disk location the backup complete message appears.
