I converted a bunch of videos in TMPGenc, and forgot to change the video sequence header. And its gonna be a pain to convert them again.
Is there a way to not convert them all again, and just change the video sequence header?
mpeg-vcr has a GOP-fixer that has always worked for me when in your situation.
If it's just the Sequence header error (and not the GOP length error) then you should just be able to demux and remux with TMPGEnc > MPEG Tools. I think there's a guide on how to do this for VCD in the guides section written by vitualis, so you'd need to set the system stream type to MPEG-2 (Program) for DVD.If in doubt, Google it.
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 09:58 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)?!
By Bruxo in forum Authoring (DVD)Replies: 0Last Post: 27th Jan 2008, 21:34
