Hello, I need some help on how I'd go about coding a program to capture and write/encode to an avi with either the Huffy UV or mjpeg codecs. I do not want to use windows "CRAM" codec. Any help is greatly appreciated even if it's just a point in the right direction. Thanks.
The most siplme way it to use DirectShow architecture.
Have a look at any capture DIrectXSdk samples, it seems to me almost all ones can perform task you mentioned.my AVI Trimming guide
https://www.videohelp.com/forum/viewtopic.php?t=283241
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
Re-write GOP structureof DVB capture.
By thefireman in forum DVB / IPTVReplies: 3Last Post: 28th May 2009, 18:32 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20 -
Why won't image burn allow me to write AVI?
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 15th Nov 2007, 18:26
