Does anyone know where I might download the mpeg2enc binary for the 0.0.9s version of ffmpegX? I have the binaries for mencoder and mplayer, but the mpeg2enc I downloaded from http://mjpeg.sourceforge.net/MacOS doesn't seem to work.
I'm trying to convert some .asf camcorder files and I haven't had luck extracting the audio with the 0.0.9u or 0.0.9t versions.
Results 1 to 10 of 10
I can't seem to get that to work with the 0.0.9s install. I keep getting an error message:
"The installation was not successful.
##cp: /Library/Application Support/ffmpegX/mpeg2enc: No such file or directory"
(I have been able to install 0.0.9t and 0.0.9u successfully previously)
Before I installed another version of the program, I deleted the ffmpegX folder in Applications Support. I also repaired permissions, but I still can't seem to install the s version of ffmpegX.
I'm a little confused about the versions of the program. Using the "t" version I can extract/convert video from an .asf file, but not audio. Using the new "u" version, my .asf file shows up as an unrecognized file type and I cannot convert it at all. I also read that the "s" version was able to fully convert .asf files, but I can't seem to get it installed on my system. Any recommendations?
As I said in the e-mail I wrote you, I was able to use ffmpegX s to convert my .asf files from my camcorder to mp4 files that QT can play. My case was a little different because my asf files were already encoded in the MPEG4 video codec. My camcorder recorded the audio in the G.726 codec. That is also different than the codec that your camcorder used.
Maybe major can tell you whether ffmpegX will be able to convert your files.
I need actual clips to test decode status, you can use yousendit.com to send to me to major4@mac.com
mpeg2enc binary not working
By yabastamedia in forum ffmpegX general discussionReplies: 1Last Post: 19th Jan 2011, 13:02 -
Problem opening mpeg2enc binary
By itegil in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2010, 23:48 -
Can't install mpeg2enc binary
By cpwhaley in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2008, 14:50 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 04:47 -
mpeg2enc binary link does not Work
By loveformetal1 in forum ffmpegX general discussionReplies: 5Last Post: 6th May 2007, 07:40
