Hi ALL,
When decrypting some defective DVDs, with DVD Decrypter, it asks if I want to ignore the errors. My doubt is: does this sequence of trials to read/ignore cause any harm to the DVD recorder?
Thanks in advance!![]()
Best regards,
Joelson. -
Constantly reading through errors will put some strain on your DVD drive. Will it burn it out after a few tries ? NO. Will it shorten the life by a year or so ? Maybe. But when a new model comes out every 7.576 minutes, speeds increasing with every 10 th model change, and the price constantly dropping - does it really matter ?
Short answer is yes, but inconsequentially.Read my blog here.
Specifically, it is like reading many dvds instead of one, because of the retrys. Would it dissuade me? No.
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
Just be aware that repeated CRC read errors can cause WinXP to drop that IDE channel from DMA to PIO. If your drive suddenly seems much slower be sure to check this. This is usually the reason for a DVD drive to drop to PIO for "no reason".
No actual harm comes from this and you can easily switch back to DMA.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Skipping errors can result in the final burnt disc to pause or lock up during playback. Allowing it to continually try and read through the error can result in damage to your laser, laser lens, or other mechanical problems down the road due to excessive heat. My suggestion is that if you plan to do a lot of disc reading buy a burner or rom specifically for reading and saving your best quality writer for burning only. The prices of optical drives make this easily affordable.
Merge two defective DVD's into a working one
By ET3D in forum EditingReplies: 3Last Post: 3rd Oct 2010, 00:14 -
Software for recovering a defective DVD
By base689 in forum MediaReplies: 5Last Post: 26th Sep 2007, 02:07 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 02:01 -
Possible to rip a defective DVD?
By gail22 in forum Newbie / General discussionsReplies: 37Last Post: 22nd Sep 2007, 14:02 -
Trying to figure out if LG Recorder is defective.
By anakin66 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 29th May 2007, 16:43
