    Oct 2005
    I have a short mpeg file in "portrait" orientation. Are there any filters to change the orientation to landscape? I've been searching through the Tools and Forum without much success. Thanks.
    May 2001
    Try this Avisynth script:
    mpeg2source("c\your file path")
    turnleft()
    or
    turnright()
    This will rotate your video 90 degrees right or left.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Oct 2005
    Thank you. I'll give it a shot.
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You don't mean fullscreen display vs. widescreen display, do you?
    Oct 2005
    Zippy, the camera was held sideways.
    SLK, Avisynth worked great but only converts 5 seconds of the clip. Here is my script (clip was mpeg1):
    LoadPlugin("c:\mpeg2dec3.dll")
    mpegsource("c:\kenmovie2.mpg")
    turnright()
    Any thoughts?
    Edit: Just wanted to add, that I suppose the "problem" is that mpeg2dec3.dll only supports Mpeg2 and it stalls on the first I frame.
    May 2001
    I'm not familiar with the "mpegsource" command.
    Try this:
    directshowsource("c\your file path")
    turnleft()
    or
    turnright()
    Oct 2005
    SLK, using directsource worked great. After posting my question I converted the file to avi in VirtualDub and then ran:
    avisource("c:\kenmovie2.avi")
    turnright()
    It had also worked. I appreciate your help. Thanks.
