I’m hoping that this is just a wrong setting on my part. When I capture from my VCR using the Hauppauge WINTV card that came with my HP Computer I don’t always get a useable file.
When I do a manual start and stop with the capture portion of the Sony software that came with the computer I get nothing but a corrupted file. When I use the timer I get a file but often it’s been stopped before the timer stops; leaving me with another useless MPG file.
I’ve checked the settings in the options part of the software, but can’t see anything that doesn’t match the hardware I have.
I’d like to keep the capture card I have; I’d just like it to work properly. Maybe someone has run into this before and has found a solution I’d appreciate knowing the answer.
Cwbyup
Have you tried using the Hauppage software? If it's not on your computer it can be downloaded from their site. BTW while your there make sure you have the latest drivers for your card too.
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 16:18 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 2nd Jul 2009, 23:57 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 14:13 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
