Hi
Just purchased this Panny DVD recorder, is there any software that will allow me to read a recording from a DVD-R R/W on my PC without having to finalise the DVD.
Regards
Dave
There is. Download ISOBuster, then in the program select the disk, and export the tracks which are the large ones ie. mbs rather than kbs (the kbs are prob title info, where as mb ones are the video files which are saved as .vob in finalisation). When its finished copying it to your hard disk, rename the extention from .raw or watever it is, to .vob - then open in a video program eg. powerdvd etc.
As far as im aware, you wont be able to read the disk in any video player program straight from the disk drive, without finalising, because as you may have noticed, xp doesnt recognise that theres anything on the disk.
Oh yeah btw, your dvd reader/writer must be able to read DVD-R (Or RW). I found my dvd reader which is meant to read dvd-r didnt work i dont think.. but with my dvd burner in pc, it reads fine (should on burners which do that type of disk).
http://www.smart-projects.net/isobuster/
The free version will work fine for getting the vids off your disk. -
I use +RW's in my lite-on and have no need to finalize them, b/c you can't. They read just fine in my computer.
"Art is making something out of nothing and selling it." - Frank Zappa -
That's because the RW is most likely used as a DVD-VR disk (like dvd-ram also). That's why a PC will let u play it, because it will recognise it as that. However, PC's wont read a dvd-r disk as a dvd-video until it's finalised.
I just noticed in the original post, it does say RW as well. My panasonic wont take RW, but assuming the RW is like dvd-ram recording, u might be able to play that directly in a program like powerdvd.
Panasonic DMR-ES46V can't read blank DVD+Rs?
By DJThuht in forum Newbie / General discussionsReplies: 8Last Post: 5th Apr 2014, 00:31 -
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Sep 2012, 13:14 -
Panasonic DMR-ES20D (PAL) Turn Off TBC/Stabilizer?
By shabi-ul in forum DVD & Blu-ray RecordersReplies: 5Last Post: 25th Oct 2010, 00:52 -
Finalise and Unfinalise
By When in forum Authoring (DVD)Replies: 6Last Post: 6th Aug 2008, 07:05 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 13:04
