  1. Member venomva's Avatar
    Feb 2003
    Long Beach, CA
    I think they are both Spyware. Has anyone run across a way to remove them? Please help.
    Thanks in advance,
    V
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I assume you've already tried to usual suspects? Like Ad Aware?
    If so I'd suggest getting a copy of hijackthis and either post the logs here (not my specialty) or on one of the many forums setups these days for spyware removal help.
  3. Member isogonic's Avatar
    Jan 2003
    @localhost
    you might also try ewido security suites. w2k, xp only. if thats not your OS try a squared personal. if you get hjt, which will only show some "hiding places" of malware-- post the log here if you want. ive seen many hjt logs.
    http://www.ewido.net/en/download/
    http://www.emsisoft.com/en/software/free/
    some general info links here at my website:
    http://members.cox.net/dma98/
  4. Member venomva's Avatar
    Feb 2003
    Long Beach, CA
    Thanks for the reply guys, here is the HJT log:
    Logfile of HijackThis v1.99.1
    Scan saved at 4:50:16 PM, on 12/1/2005
    Platform: Windows XP SP2 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\winlogon.exe
    C:\WINDOWS\system32\services.exe
    C:\WINDOWS\system32\lsass.exe
    C:\WINDOWS\system32\svchost.exe
    C:\WINDOWS\System32\svchost.exe
    C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    C:\Program Files\Intel\Wireless\Bin\ZcfgSvc.exe
    C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
    C:\WINDOWS\Explorer.EXE
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    C:\WINDOWS\system32\spoolsv.exe
    C:\PROGRA~1\Intel\Wireless\Bin\1XConfig.exe
    C:\WINDOWS\system32\basfipm.exe
    C:\Program Files\Symantec AntiVirus\DefWatch.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTBCM\Binn\sqlservr.exe
    C:\Program Files\Dell\NICCONFIGSVC\NICCONFIGSVC.exe
    C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    C:\Program Files\Symantec AntiVirus\Rtvscan.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
    C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe
    C:\Program Files\Dell\QuickSet\quickset.exe
    C:\WINDOWS\system32\dla\tfswctrl.exe
    C:\Program Files\Microsoft AntiSpyware\gcasServ.exe
    C:\Program Files\Common Files\Symantec Shared\ccApp.exe
    C:\PROGRA~1\SYMANT~1\VPTray.exe
    C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd.exe
    C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
    C:\WINDOWS\addaw.exe
    C:\WINDOWS\system32\ctfmon.exe
    C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    C:\Program Files\Digital Line Detect\DLG.exe
    C:\WINDOWS\mfcpg.exe
    C:\Program Files\Microsoft AntiSpyware\gcasDtServ.exe
    C:\Documents and Settings\All Users\Start Menu\Programs\Utililties\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://moneycentral.msn.com/investor/home.asp
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dell.com
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://www.dell.com/
    R3 - Default URLSearchHook is missing
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: Class - {410B27BA-B345-48F4-E620-AAFDD2B7C25A} - C:\WINDOWS\system32\ieow.dll
    O2 - BHO: Class - {513F52ED-5623-F228-1042-41F0E0AEBDA9} - C:\WINDOWS\sysnm32.dll (file missing)
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
    O2 - BHO: Class - {78422535-0B83-4512-E72F-E424D322FD00} - C:\WINDOWS\addmi.dll (file missing)
    O2 - BHO: Class - {905BD5E4-261C-4EFD-5456-CD124D7B9D18} - C:\WINDOWS\system32\apijy.dll (file missing)
    O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe
    O4 - HKLM\..\Run: [IntelWireless] C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe /tf Intel PROSet/Wireless
    O4 - HKLM\..\Run: [Dell QuickSet] C:\Program Files\Dell\QuickSet\quickset.exe
    O4 - HKLM\..\Run: [UpdateManager] "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
    O4 - HKLM\..\Run: [dla] C:\WINDOWS\system32\dla\tfswctrl.exe
    O4 - HKLM\..\Run: [gcasServ] "C:\Program Files\Microsoft AntiSpyware\gcasServ.exe"
    O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
    O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\SYMANT~1\VPTray.exe
    O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd.exe"
    O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
    O4 - HKLM\..\Run: [95.tmp] C:\DOCUME~1\DAVEBA~1\LOCALS~1\Temp\95.tmp.exe
    O4 - HKLM\..\Run: [96.tmp] C:\DOCUME~1\DAVEBA~1\LOCALS~1\Temp\96.tmp.exe
    O4 - HKLM\..\Run: [96.tmp.exe] C:\DOCUME~1\DAVEBA~1\LOCALS~1\Temp\96.tmp.exe
    O4 - HKLM\..\Run: [95.tmp.exe] C:\DOCUME~1\DAVEBA~1\LOCALS~1\Temp\95.tmp.exe
    O4 - HKLM\..\Run: [addaw.exe] C:\WINDOWS\addaw.exe
    O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - Global Startup: Acrobat Assistant.lnk = C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
    O4 - Global Startup: Digital Line Detect.lnk = ?
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_03\bin\npjpi142_03.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\j2re1.4.2_03\bin\npjpi142_03.dll
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
    O16 - DPF: {04E214E5-63AF-4236-83C6-A7ADCBF9BD02} (HouseCall Control) - http://housecall60.trendmicro.com/housecall/xscan60.cab
    O16 - DPF: {3DC2E31C-371A-4BD3-9A27-CDF57CE604CF} (MSN Money Charting) - http://moneycentral.msn.com/cabs/pmupd806.exe
    O16 - DPF: {7B297BFD-85E4-4092-B2AF-16A91B2EA103} (WScanCtl Class) - http://www3.ca.com/securityadvisor/virusinfo/webscan.cab
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
    O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxsrvc.dll
    O20 - Winlogon Notify: IntelWireless - C:\Program Files\Intel\Wireless\Bin\LgNotify.dll
    O20 - Winlogon Notify: NavLogon - C:\WINDOWS\system32\NavLogon.dll
    O23 - Service: Broadcom ASF IP monitoring service v6.0.4 (BAsfIpM) - Broadcom Corp. - C:\WINDOWS\system32\basfipm.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    O23 - Service: Symantec AntiVirus Definition Watcher (DefWatch) - Symantec Corporation - C:\Program Files\Symantec AntiVirus\DefWatch.exe
    O23 - Service: EvtEng - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    O23 - Service: NICCONFIGSVC - Dell Inc. - C:\Program Files\Dell\NICCONFIGSVC\NICCONFIGSVC.exe
    O23 - Service: RegSrvc - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    O23 - Service: SAVRoam (SavRoam) - symantec - C:\Program Files\Symantec AntiVirus\SavRoam.exe
    O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
    O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
    O23 - Service: Symantec AntiVirus - Symantec Corporation - C:\Program Files\Symantec AntiVirus\Rtvscan.exe
    O23 - Service: WLANKEEPER - Intel® Corporation - C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
  5. Member isogonic's Avatar
    Jan 2003
    @localhost
    hi,
    not at home right now, going thru this quick. start with this: start hjt place a checkmark by these items, close all windowsw and click "fixed checked"
    reboot once, rescan and post anew hjt log...
  6. Member isogonic's Avatar
    Jan 2003
    @localhost
    iam going to assume youve done the above. i would copy this to a txt file and save it somewhere as we will be in SAFE MODE.
    make sure files are set to show:
    FOr XP: on the desktop double click my computer,go to tools>folder options>view> then select "show hidden files and folders", then UNcheck "hide protected operating system files " also UNcheck "hide extensions for known file types" click apply to all folders, apply then ok
    reboot computer into safe mode. you reach safe mode by tapping the f8 key during a restart. chose safe mode from the list of options. once in SAFE MODE
    look in the C:\WINDOWS dir for these two files:
    addaw.exe
    mfcpg.exe
    delete just those two
    while in safe mode do this:
    click Start>Run then type %temp%
    Hit OK. Delete all the files you can.
    Go to Start > Run and type:cleanmgr. Windows will scan. When done check these 3 and press *ok* to remove:
    Temporary Files
    Temporary Internet Files
    Recycle Bin
    reboot once, rescan with htj, post a new log
  7. Member Guy_Fawkes's Avatar
    Nov 2005
    This what i've found regarding searcterror.com
    http://www.kephyr.com/spywarescanner/library/exploit-searchterror.com/index.phtml
    Detection
    Bazooka Adware and Spyware Scanner detects Exploit searchterror.com. Bazooka is freeware and detects spyware, adware, foistware, trojan horses, viruses, worms and other potentially unwanted applications. Read more »
    Uninstall procedure
    Uninstall Exploit searchterror.com from "Add/Remove Programs" in the Windows® Control Panel. Look for entries called "SpySheriff" and "WierdOnTheWeb".
    Manual removal
    Please follow the instructions below if you would like to remove Exploit searchterror.com manually. Please notice that you must follow the instructions very carefully and delete everything that is mentioned. In most cases the removal will fail if one single item is not deleted. If Exploit searchterror.com remains on your system after stepping through the removal instructions, please double-check by stepping through them again.
    Start your computer in safe mode.
    Start the registry editor. This is done by clicking Start then Run. (The Run dialog will appear.) Type regedit and click OK. (The registry editor will open.)
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Classes \ CLSID \ {A0269420-A638-4509-889C-8FC3CC85DA7E}', if it exists.
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Classes \ CLSID \ {B75F75B8-93F3-429D-FF34-660B206D897A}', if it exists.
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Classes \ CLSID \ {FFF5092F-7172-4018-827B-FA5868FB0478}', if it exists.
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Browser Helper Objects \ {A0269420-A638-4509-889C-8FC3CC85DA7E}', if it exists.
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Browser Helper Objects \ {B75F75B8-93F3-429D-FF34-660B206D897A}', if it exists.
    Delete 'HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Browser Helper Objects \ {FFF5092F-7172-4018-827B-FA5868FB0478}', if it exists.
    Browse to the key:
    'HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Run'
    In the right pane, delete the values called 'System', 'PayTime', 'ICDRegOCX0', '_Cat4', 'Disk Keeper', 'Systems Restart', 'Service Host', 'WeirdOnTheWeb', 'WindowsUpdate' and 'load32', if they exists.
    Browse to the key:
    'HKEY_CURRENT_USER \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Run'
    In the right pane, delete the values called 'SpySheriff', 'PayTime', 'Windows installer' and 'wupd', if they exists.
    Exit the registry editor.
    Start Windows Explorer and delete:
    c:\loader.exe
    c:\mailz.txt
    c:\sys.exe
    c:\tmp.txt
    c:\trig.dtl
    c:\winstall.exe
    %WinDir%\weirdontheweb_topc.exe
    %WinDir%\zsettings.dll
    %WinDir%\tool1.exe
    %WinDir%\tool2.exe
    %WinDir%\tool3.exe
    %WinDir%\svchost.exe
    %WinDir%\ms1.exe
    %WinDir%\ms2.exe
    %WinDir%\ms3.exe
    %WinDir%\ms4.exe
    %WinDir%\msmsgr2.exe
    %WinDir%\drexinit.dll
    %WinDir%\kernels32.exe
    %WinDir%\vr_sys.dll
    %WinDir%\desktop.html
    %WinDir%\dvpd.dll
    %WinDir%\installer_SIAC.exe
    %WinDir%\sasent.dll
    %WinDir%\sasetup.dll
    %WinDir%\cdmweb\
    %SystemDir%\latest.exe
    %SystemDir%\maxd.exe
    %SystemDir%\newdial.exe
    %SystemDir%\realupd32.exe
    %SystemDir%\realupd_32.exe
    %SystemDir%\thn.dll
    %SystemDir%\thn32.dll
    %SystemDir%\tibs.exe
    %SystemDir%\vx.tll
    %SystemDir%\init32m.exe
    %SystemDir%\cssrs.exe
    %SystemDir%\abc.exe
    %SystemDir%\paytime.exe
    %SystemDir%\vxgame1.exe
    %SystemDir%\vxgame2.exe
    %SystemDir%\vxgame3.exe
    %SystemDir%\vxgame4.exe
    %SystemDir%\win32.exe
    %SystemDir%\newdial1.exe
    %SystemDir%\zolk.dll
    %SystemDir%\ztoolber.dll
    %SystemDir%\ztoolbar.xml
    %SystemDir%\~update.exe
    %ProgramsDir%WeirdOnTheWeb\
    Note: %WinDir% is a variable (?). By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\WINNT (Windows NT/2000).
    Note: %SystemDir% is a variable (?). By default, this is C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP).
    Note: %ProgramsDir% is a variable (?). By default, this is C:\Program Files.
    Start Microsoft Internet Explorer.
    In Internet Explorer, click Tools -> Internet Options.
    Click the Programs tab -> Reset Web Settings.
