I have a DVD thats 7 gb in size, the actual film itself is only an hour or so long, the extras taking up 2 hours of footage.
I want to be able to rip just the movie and burn that to a dvdr without having to re-encode the movie and loose any quality. How do I do this?
Im new to ripping etc, so any help will be appreciated.
If you don't need the menus, rip it to your HDD using DVD Fab Decrypter, load it into DVD Shrink, click on Re-Author and drag just the movie to the left-hand pane. If it fits, Shrink will create a new, smaller DVD with just the movie (and chapter stops, but no menus), ready for burning (if you have Nero, CopytoDVD or VD Decrypter installed, it can burn as well).
If the movie is still too big, tick Deep Analysis and AEC, and Shrink will reduce the size to fit a single disk.
If the amount Shrink needs to Shrink to is too large (for me this is 90% or smaller), DVD Rebuilder with CCE or ProCoder will give you the best quality output.
All of these tools are free, with the exception of
Nero
CopytoDVD
CCE
ProCoderRead my blog here.
Why not just split the movie?
Works well no loss. Or at least less than compressing.
Also if it has more than on esoundtrack the others can be removed. Frequently that makes a large dvd much smaller. -
The easiest option I've found for someone new to doing this is CloneDVD2. Everything is done with a user interface that provides previews of what you are including or removing. You just check what you want, including the option of keeping or removing menus. They have a trial available that is fully functional. I highly recommend it.
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 16:52 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 10:33 -
DVD9->DVD5, Best results?
By indijay in forum DVD RippingReplies: 27Last Post: 15th May 2009, 10:34 -
Opera DVD9 to DVD5 - Best way?
By ChessPlayer in forum DVD RippingReplies: 9Last Post: 2nd Oct 2008, 14:02 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 20:36
