    Dec 2004
    My internal DVD burner finally gave out. I bought an external, which works fine. I am trying to upgrade to 10.4, I put in the install disc, double click the installer and when it ask me to restart I say ok. It tries to restart from the install disc, but it is looking at the old drive and sees nothing there. how can I force it to look at the new drive to find the install disc?
    A picture is worth a thousand words, but a good camera is worth about a thousand bucks.
    Dec 2003
    Eugene, Oregon
    Try using the Startup Disk panel in System Preferences (from your Mac) to select the startup volume on the DVD.
    Dec 2004
    It worked. Thank You!!
    I love 10.4.3
