It seems like when i insert a VCD in my Apex AD-1500 that it makes a noise like for example when u have the TV on mute and u close your eyes you know its on by like the ringing noise sort of... anyways... i think it may be from the (red white yellow) cables and how when i want to see the movie i have to switch the TV mode to AUX-IN. could that be the problem i dont know. someone help me please
thanks
<font size=-1>[ This Message was edited by: GreenHawk14 on 2001-12-25 18:42:08 ]</font>
It's only when playing a VCD... not when a DVD is played... a DVD is fine... so i don't think it is the method of connecting... i think it happens when it reads the VCD... is it the CD-R I'm using? I'm using Imation... whats the best for playback in a DVD player?
If it's a light feedback hum, capture at lower volume. Disconnect stereo cables one at a time, if isolate channel determine if capturing/encoding stereo, try upping bitrate. I think Azid or something like that will eliminate this if it's a sampling artifact, but I haven't tried this yet.
I'm having the same problem, but with plain old DVD's, out of the box. I jist got the unit yesterday, adn was able to play a couple without issue. Now I'm getting that humming feedback type noise, but it's not low; it overpowers the audio. I've tried everything, and it seems that only the Left channel does it. I've hooked it directly to the TV, and through a VCR. I'm low tech, so it's all RCA cables, analog. I know it's not about VCD's, but any help would be appreciated.
I have mine going through my VCR first then into the TV via RCA jacks. It works fine, I haven't had any problems what so ever.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
VHS Problem - LP possibly?
By Hackerpcs in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2010, 09:03 -
high-pitched screeching noise when playing back DVD, but video works...
By xSavant in forum ffmpegX general discussionReplies: 1Last Post: 26th Apr 2010, 18:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35
