I just got a new NEC 3550A burner and i tried burning my first Verbatim DVD+r DL disk. I was successful however i could not bitset the disk to DVD-ROM. I am using 1.05 Firmware and Imgburn to burn. Before i started the burn i went to the booktype setting in Imgburn, clicked on the NEC tab and chose DVD+rDL MEDIA under the "change for" setting, then on the bottom i selected "DVD-ROM". i get a window that pops up that says succsess however whe its time to burn the booktype still says DVD+R DL. im not sure what exactly im doing wrong. I should note that i am also using the hacked firmware created by Liggy and Dee from cdfreaks. it is availible at http://liggydee.cdfreaks.com/page/3550/ . If anyone has any suggesstion i would really appreciate it. thanks!
I have a 3540 and use liggy and dees 103 firmware.Using dvd identifier it says dvd+rdl-dvdrom.
The disc is identified as +r dl and booktype dvd-rom.Just a thought.You might want to try this program.bmiller,ont.canada
Does the Memorex MRX-530L DVD Writer supports bitsetting?
By The__Hermit__1971 in forum DVD & Blu-ray WritersReplies: 10Last Post: 27th Apr 2013, 20:44 -
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 13:39 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:58 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 22:33 -
Really, really weird issue with NEC 3550A
By ioannisds in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st Jul 2007, 14:07
