Hello:
I have been testing with ffmpegx for 2 weeks now but couldn't get good result overall, please provide any advice if possible.
What I want to achieve:
vob --> mp4 (I want to have the best video quality possible)
video codec: H.264 with bitrate of 4000kbps
audio: AAC 192k
screen size: 7200 x480
Issue #1: Even I specified 4000kbps constant bitrate, the encoded file of mp4 is always between 2500 to 3600kbps. How can I have a fix bitrate ?
Issue #2: I can't "join" all 4 vob files using ffmpegX. The error message says it doesn't support this video format yet.
Issue #3: Playing back encoded file on Mac is fine, but playing back on PC the picture quality is much darker.
Thanks in advance,
Dan
For best video quality, do not transcode.
#1: For good quality in H.264 at DVD resolution, 1213 kbit/sec is enough. (Click 'Best' button in the bitrate calculator.) 4000kbps may simply be more than needed for this codec. If x bytes are enough to describe a scene accurately, then there is no reason to use x+y bytes. Why the fixed bitrate, constant quality, thus VBR, seems closer to your goal?
#2: Use your ripper to output a title in a single vob.
#3: ?
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25
