Ok, all my burns have worked one way or another (different programs) ie shrink, decrypter, dvdfab, anydvd etc you know the deal
however, I ripped madagascar with fab w/ anydvd in the background but now when I try to shrink it, it codes slower, and different, and then more than half way through it, it will come up with an error message about quitting the program because of virtual memory paging file
so I go in and change the virtual memory paging file so more can be accessible. However, now when I do the encoding, it still does the same thing however, the buffering gets really high!
anybody know a way around this? its already ripped with dvdfab, I just need it shrinked and burned
How about posting the fix so that if any one else searches this forum for the same problem they can get an idea of how to fix it for themselves ?
Not a criticism, but it would just be helpful for other users.
just go into the task manager and change your virtual memory to suit your needs and your harddrives
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
virtual memory too low?
By deadman1972 in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 09:22 -
VLC Media Player hangs and starts hogging lots of Virtual Memory
By shiningwizard in forum Software PlayingReplies: 2Last Post: 27th Aug 2008, 08:17 -
Xvid4PSP making Windows give Virtual Memory low message
By godfist314 in forum Video ConversionReplies: 5Last Post: 22nd Jul 2008, 14:09 -
how do you receive virtual memory?
By mvp in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2007, 07:46
