I have an mpeg1 video file that I'd like to add some photos to. I don't have the original video footage to edit this video in premiere. Is there any sort of software I can use to edit still photos into this mpeg1 video?
Without losing quality?
You can certainly edit MPG video in most editors worth their salt, however you'll be re-encoding the video which will hurt the quality of the original film. -
If I use the Merge & Cut tool - will this cause cuts in the audio? I would like to simply overlay some photos over sections of the existing video - so the mpeg1 file will be the same running time as the original file.
No, it will extend the lenght of the video.
You could make the photo clips with the section of audio that you will cut from the video file and add latter. Would be a lot of work if you have many photos to add, and you MAY end up with audio sync issues.
Regards,
Chas
taking stills from video
By angryassdrummer in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2011, 02:53 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 18:38 -
Best way to add stills to audio
By PrepositionJoe in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2010, 05:53 -
Playing Stills and Video on a TV??
By reman in forum Newbie / General discussionsReplies: 7Last Post: 2nd Oct 2008, 15:27 -
Short video clip to stills
By swkenney in forum Video ConversionReplies: 2Last Post: 16th Sep 2007, 13:25
